Late model fuel pump in Early model
  • Ian Bowers
    • Apr 2008
    • 1120
    Hey guys, just needing some clarification:
    I have an 87 325e, in-tank transfer pump with the high pressure in front of the driver's rear wheel. I went down and grabbed my 91 318iS in-tank pump and the assembly, as well as the correct plug-end. From the threads that I can find, I replace the large 3/8ths hose with 5/16ths to the fuel filter, remove the high pressure pump, and all works as intended?
    Thanks,
    Ian
    Yep.
    • Swanny
      • Mar 2012
      • 2834
      Just use the old level sender or your gauge is going to be all wacky.
      Swanny!
      SUCKERS.
      • Ian Bowers
        • Apr 2008
        • 1120
        so, the car isn't getting fuel. Any ideas? I can hear the pump running when cranking. Only thing I can figure is that I might have reversed the lines? I went over them several times and they're correct, but stranger things have happened...
        Also, thanks for the help guys, I do appreciate it.
        • Swanny
          • Mar 2012
          • 2834
          Check for a plugged fuel filter? I'd test that first but while you have the line off under there put a bucket underneath, crank the car for a bit, and see if you have fuel. Hook the filter back up and then do the same thing from the fuel rail.
          Swanny!
          SUCKERS.
          • Ian Bowers
            • Apr 2008
            • 1120
            Fuel filter is about two weeks old, definitely not plugged. Bucket test sounds like a plan.
            • Ian Bowers
              • Apr 2008
              • 1120
              Lines were reversed at the pump... Anyone have a dunce hat for me?
              • TobyB
                • 5297
                Sure. Once I'm done wearing it...
                The gauge will work fine, though, since all the senders were the same.
                t
