Odd vent issue
  • 603Racing
    • Dec 2010
    • 612
    Odd vent issue
    '84 eta. My floor and uppers work perfectly, as well as the temp control. The dash vents blow air correctly for the fan speed setting, but they are always pulling in outside air. When it was cool outside this morning, I had hot air from the floor and upper vents, but the dash vents were blowing in cold air. No change when I push the recirculate button. I can shut off the dash vents with the slider, but I cannot control the air temp coming from them.
    Any ideas?
    90 325i DD/Track
    03 Durango 5.9
    Originally posted by e30mpg
    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
  • 603Racing
    • Dec 2010
    • 612
    What day is it? Bumpday! Yeeeah!
    90 325i DD/Track
    03 Durango 5.9
    • jalopi
      • 2370
      No responses, well, because that is some mind-boggling shit right there. I mean, the blend door and recirculation door should affect all the vents... what you need is a HVAC diagram. That'll contain the insight you need bro.
      • 603Racing
        • Dec 2010
        • 612
        I was afraid of that. :)
        It's definitely f'ing weird. The only thing I can think of is the fresh air flapper is stuck open in one spot that feeds to the dash vents. I was under the impression that all the vents pulled through the heater core at the same time... I guess not.
        90 325i DD/Track
        03 Durango 5.9
        • jalopi
          • 2370
          Ok... so this just hit me. Zero basis behind it, it's just that old german manufacturers used to do some wacky shit. Maybe there are separate doors for each vent 'type'? That might be the case, considering there's three sliders.
          There could be an issue where the door is bound up for the 'middle' vents... although I'm really just pulling this out of my ass. Powers of deduction or whatever. Something to look in to?
          • TobyB
            • 5297
            Or someone stuck E36 vents in there, they can do that.... naw, that's not it, either!
            t
            • 603Racing
              • Dec 2010
              • 612
              Jalopi, you are probably on to something. Because out of nowhere, it's working fine now.
              90 325i DD/Track
              03 Durango 5.9
              • jalopi
                • 2370
                weird
