fuel line replacement?
  • jalopi
    • 2370
    Most line can be bent by hand with steady, even pressure. SS lines are the ones you really need a bender for.
    Also, having a flaring tool is something good to have when you consider how much most shops charge for line jobs. Besides, since when is having tools a bad thing?
    • FLG
      • Sep 2011
      • 3165
      I have all the tools and I'd still rather just buy the line pre bent then waste my time measuring, cutting, bending, and flaring.
      Sent from my SCH-I545 using Tapatalk
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • SmokeE30
        • 1730
        Agreed I did the job recently and it's so easy when you have pre bent factory lines to just bolt up. I think it was around $60 for the feed and return hose lines pre-bent and ready to go from pelican.
        Shawn @ Bimmerbuddies
        Bimmerbuddies LLC
        717-388-1256
        2971a Roundtop Rd, Middletown PA 17057
        bimmerbuddiesllc@gmail.com
        • cosmowilly
          • Sep 2016
          • 4
          ordered my parts will be doing the fuel pump with it's soft lines and the fuel filter and soft lines.
          I'll get to the soft lines in the front when I do the Injectors and Rail.
          Thanks for the heads up always down to save money if I can do it myself. spent under $200 for OEM BMW Hoses and Rings.
          • digger
            • Nov 2005
            • 6059
            So the e30 fuel hard lines are 5/16" (8mm) OD? what is the ID?
