89 e30 door lock
  • turk1shk1d
    • Oct 2013
    • 119
    89 e30 door lock
    Ok so today I come outside to go to work... but when I tried getting in my car.. the lock did not turn at all.. I thought it was the key but I tried my other key and it doesnt work.. I opened it from the trunk but I cant lock my doors or anything.. the locks do not move at all... it is cold out, so im guessing that is why... what can I do to fix it? Wd40 would be enough?
    Sent from my SGH-M919 using Tapatalk
  • FLG
    • Sep 2011
    • 3165
    Its not that cold out here yet, though if your upstate maybe a bit lol
    So both passenger AND driver door locks arent turning?
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • AndrewBird
      The Mad Scientist
      • 11898
      Don't use WD-40. Use something like 3-in-1 or Tri-Flow.
      If oiling them doesn't work, the actuators in the door may be bad. Does the passenger side lock work?
      • turk1shk1d
        • Oct 2013
        • 119
        The key wont turn on both pass and driverside.. trunk works.. the lock handles on the side of the door dont move unless I move them... when I put them in lock position and I shut the door the door closes and opens normally.. if I dont do that it doesnt close... and its wierd cause when I lock or unlock from the trunk door lock buttons dont go up or down and the door opens and sometimes doesnt open at first... idk what is going on... how to I grt to the lock it self
        • turk1shk1d
          • Oct 2013
          • 119
          Ok so here is the update guys... I can only play alittle with the driverside lock and non with the passenger side... the passangerside keyhole is on unlock position.. the driverside key hole is stuck at lock postion... if I turn it all the way to take out the key from driverside u hear a little click (meaning its locked)... when I do that I cant even unlock or lock my car from the trunk... but if I turn it where I can take out my key without the click I can unlock and lock my doors from the trunk and it works perfectly.. so im ok with that as of right now.. but what do I have to do? Rebuild my driverside? Can I get a new lock?
          • jalopi
            • 2370
            Can you unlock the drivers' door from inside the car? If not... well, that's going to suck.
            In any case, the arm on your lock cylinder is probably broken. This is what locks and unlocks the doors when you turn the key.
            • turk1shk1d
              • Oct 2013
              • 119
              No I cant.. I cant push or pull the lock button.. so im guessing I need to rebuild it?
              • jalopi
                • 2370
                Make sure your inside door handle is 100% 'closed'. I recently had an issue where the handle would catch on the handle bezel and prevent the door from locking.
                Either that or you 'double locked' your doors and then the arm on your lock cylinder broke. If that's the case, you're in for a world of frustration. Does your drivers' door open?
                • turk1shk1d
                  • Oct 2013
                  • 119
                  Yea the doors open and close... the locks work perfectly from the trunk.. im ok with the way it is rn.. but I just want to know what could be the problem if I fix it later
                  • jalopi
                    • 2370
                    Aaah, well if that's the case (if your doors open and everything locks/unlocks from the trunk) you need a lock cylinder for the drivers' door. It's called a rebuild kit, but really it's an entire lock that you build from scratch.
                    You can buy it here from Pelican:
                    http://www.pelicanparts.com/cgi-bin/...2533%2520%2520
                    or you can get it from the dealership (surprisingly) for a few bucks cheaper.
                    Just pull your door panel first to confirm that the arm broke off on the lock cylinder.
                    • jeffnhiscars
                      • Jun 2011
                      • 6010
                      Even if the doublelock arm is not broken the ball detent can wear a deep groove in the lock barrel with the same results. The rebuild kit would be a good plan.
                      Alice the Time Capsule
