Hood won't open!!
  • ac3
    • Jan 2011
    • 121
    Hood won't open!!
    My hood won't open! The hood release pulls so far out that I had to remove the under dash trim. I still feel resistance but I'm afraid to pull any harder without snapping the cable or handle... any ideas? Help!!
  • dnguyen1963
    • Nov 2011
    • 2651
    You can pop open the hood from the front with a screw driver then examine the cable from there to see if it needs replacement.
    • EyExR
      • Jan 2011
      • 959
      My 325iX DIY Threads:
      Front Wheel Bearing Replacement
      325iX Rear Subframe Bushings and MUCH more w/pics!
      325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
      • jalopi
        • 2370
        When you do get the hood open, lube the hell out of all four hinges. Yes, four. Then work the hood forwards/backwards until it's easy to work and you'll be good to go.
