timing belt...
    Take out the water pump, tensioner, then belt.
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
      Will
      thanks a lot man!
      i rotated it and the cam gear lined up but the dampner O|T mark isnt lining up but kinda close...is that good enough or should i keep rotating?
        Just dont let the cam gear and the crank gear move while that belt is off!!!
        Will
        DaveCN = Old Man
          Remember the cam rotates twice for every one revolution of the crank.
          Will
          You sure about that?
          Matt
            Does the crank rotate twice for every cam gear rotation? I always get it mixed up.
            Will
            DaveCN = Old Man
              I remember my marks weren't EXACT after turning the crankcase 4 revolutions. One of them was about a millimeter or two off, I don't remember which one though.
                Will
                Yup.
                Smaller = turns more.
                Matt
                  My bad. I just changed the timing belt and water pump on my new engine at work today outside the car so my memory on how to do it has been refreshed. :) Also changed the front cam seal.
                  Will
                  DaveCN = Old Man
                    what?
                    Originally posted by PeaveyBassist View Post
                    Take the spark plugs out. Youre probably close to the compression stroke. Either that... OR you have the parking brake on and the car is in gear ;) Ask me how I know lol
                    Will
                    Just wondering, i can understand if the car is in gear, having trouble rotating but i dont understand what having the parking brake on would do? maybe i read this wrong, let me know.
                      It would only matter if the car was off the ground when the engine was rotated and would then rotate the wheels aswell if the cars emergency brake was NOT engaged. However if the cars emergency brake was set then It would stop you from rotating once again. I suppose if the car was on the ground with it in gear and no E-brake you may even move the whole car if you turned it hard enough.
                      1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
                        Guys, the crank timing mark is NOT on the lower cover!
                        It is a small notch, cast into the main seal housing. It lines up with a groove on the crank.
                        If you use this one, life is easier. Leave the toothed wheel off of the crank until you have cam timing set, then do your covers...much easier!
                        Luke
                        Closing SOON!
                        Thanks for 10 years of fun!
                          One of the most important maintenance tasks for the six-cylinder E30 engines is the replacement of the rubber timing belt. Be sure to read this article!
                          this helped me alot. good luck
