Gas leak
  • turk1shk1d
    • Oct 2013
    • 119
    Gas leak
    Ok I just want to know if its common... I just got to work today and when I walked out the car I spell gas.. looked at the floor and its dripping like crazy.. my cars really low so I cant really se where its from but the spill is by the back of the engine little to the driverside... am I in big trouble or what? If anyone has any clue let me know.. im most likely going to check it out tomorrow or wedbesday
    Sent from my SGH-M919 using Tapatalk
  • FLG
    • Sep 2011
    • 3165
    Fuel line or hose.. Your gonna need to check, we can't really help you do that.
    Sent from my SCH-I545 using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • TobyB
      • 5182
      Yah, that's where the fuel lines run- if you're really low, you may have crunched one.
      Or it just popped (poped!) a leak, what with being 20- odd years old.
      But it's a hands- on, no- smoking sort of diagnosis.
      t
      • turk1shk1d
        • Oct 2013
        • 119
        t
        Hahah... damn I cant fix anything with a cig.... I dont think I hit it anywhere... not that I knw of atleast..
        • jalopi
          • 2370
          Cigarettes don't burn hot enough to ignite gasoline, FYI.
          Have a few fire extinguishers handy and have a friend prime the fuel pump while you look for leaks. Shouldn't need the extinguishers... just in case, you know?
          • turk1shk1d
            • Oct 2013
            • 119
            Lol.. I already fixed it up.. the PO put the wrong line in so it couldnt handle it and popped.. so I just had to fined a hose and put it on... but now my check engine is on idk why I have get that checked out
            • timninja
              • Feb 2011
              • 302
              You can smoke just watch where you light that som-bitch
              • joncrz
                • Jul 2013
                • 364
                fuel lines. I had a leak back there it ended up being one of the connections that plugs into the fuel filter (it is located exactly where you are describing).
                My don't quote me list:
                I could be wrong, but I don't think it's a smog test type of thing. IIRC think it's against CA law to *sell* a dual outlet muffler as a replacement for a car that came from the factory with a single. But don't quote me on that.
                • matthugie
                  • Mar 2004
                  • 1810
                  Already fixed. Also, which e30 has the fuel filter in the engine bay?
                  88 325is - S52 powered
                  Originally posted by King Arthur
                  We'll not risk another frontal assault, that rabbit's dynamite!
                  • jalopi
                    • 2370
                    I think he meant it was a line coming from the fuel filter, not from a filter in the bay.
                    • Quadrajet
                      • Jul 2008
                      • 1278
                      325e's and 318is(M42) cars, if memory serves me correctly. Not really in the bay, I would consider it more like underneath. They lurk underneath the brake booster.
                      • joncrz
                        • Jul 2013
                        • 364
                        • matthugie
                          • Mar 2004
                          • 1810
                          Ah, that makes sense. I have only worked on late model 6 cylinder fuel systems, but knew there were some differences between models.
                          • peytonracer4
                            • May 2011
                            • 524
                            318is is under the car. in the middle
