Help me fix my sketch fitment!
  • series88
    • Nov 2011
    • 1231
    Try waiting for a used set of H&R race. Explore that option before getting shocks. Eibachs are just way too soft. My Weitec (cheap springs) on my 318 feels way stiffer than the Eibachs on my 325. The 325 feels boaty is boaty can ever be boaty. Did I mention boaty?
    • freeride53
      • 11972
      Aha. Another thing guys...should I entertain the possibility of buying used H&R race's?
      Are used springs usually softer in rates than new ones?
      Pardon my ignorance, I don't know much about suspension :D
      1983 Peugeot 505 STI
      1992 Volvo 240 Wagon
      • series88
        • Nov 2011
        • 1231
        Not really softer. More like they've settled. Which means they sit where they're supposed to be. I perosnally wouldn't mind a used set. As long as not rusty.
        • mtech325
          • May 2008
          • 569
          Originally posted by Fidhle007
          There's always Turner J-Stock...
          LOLZ J-stock!
          If you can swing it, get some Billy Sports or Konis for the rear, because correct me if I'm wrong, but aren't Bilstein Tourings an OEM replacement for stock springs? I think some serious fender rolling is in your future. Or spend 30 bucks or so and get the IE rear spring raisers which raise the car up by 3/8 inch in back (made to combat the rear rake usually found on IE3 springs).
          --Joey
          • jalopi
            • 2370
            If the used springs are super worn, then yes, the spring rate might be slightly lower.
            However.... there's a better chance of one of the spring coils breaking off from stress fatigue than becoming super goopy. Unless they're sagging, in which case you might not be able to tell without them on the car.
            • freeride53
              • 11972
              So in my conclusion, the springs are the problemo.
              hope to grab a set of very lightly used h&r race springs from Christian (bernz) over thxgiving break in 2 weeks.
              Will report back in decembah!
