Motronic 1.3 Ignition problem - Please Help
  • Hobbit
    • 16
    Hi Everyone...
    I have a weird problem with my E30. I have an M20B20 L-Jet engine swapped to Motronic 1.3. I have already changed everything, and the motronic works fine, until I reach the rpm limit on torqe. At about 6000 rpm the engine dies for a moment, but as it has an inertia it starts again. Engine does not die on revlimit, if I am in neutral, and the car does not move. It can be funny when overtaking:(
    The other symptom is if I start the car with ignition key, it starts fine. But if I can not start at the first moment, or I drowned the engine, I am not able to start it again. The second time of starting never gets the engine work. It seems, something like that the DME doesn't get cranking signal. But I can push the car into work in 2nd gear even alone.
    Has anyone an idea?:)
    Thanks
  • TobyB
    • 5297
    What DME number do you have? The late ones have a top- speed limiter, and if it's
    getting a different signal than it expects from wheelspeed, it does a funny limit-
    not at all like the rev limiter...
    t
