Sunroof getting stuck
  • e30mobber
    • 1402
    It wants to open which leads me to believe that the motor, switch and relay are fine and working so it must be track related
    Anyone have the same issues?
    Won't tilt or slide back more than couple inches
  • FLG
    • Sep 2011
    • 3165
    Can you crank it manually? (pop open little cover and use Allen key found in trunk tool kit) could be worn/broken gear on motor.
    Sent from my SCH-I545 using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • Aleman
      • Mar 2012
      • 1611
      Another trick is to stand outside the car, and push down on the rear of the sunroof panel while you push the button to slide open. This helps to get it started on its way into the rear section of the roof. Mine had this same exact problem, and once I had the sunroof opened, I discovered it was getting jammed up on chunks of rust lying in the tracks. Needed to replace the panel with a rust-free one. Works great now!
      R135 /// 1990 Alpinweiß II 325is
      └┼┼┘ /// 1993 Black/Black Convertible (sold)
      ..24
      • Cletonius
        • 2809
        Your motor could be weak/old. Mine worked fine until I replaced the seal, it was apparently too tight. A new motor cleared that up.
        - Josh
        1990 325is
        Need a shift boot?
        Looking to buy shift boot frames, PM if you have one to sell
        Here's what happens when you let the internet pick your license plate
        • e30mobber
          • 1402
          thanks guys, im gonna attack that shit this weekend
          • red baron
            • 176
            Mine has had an issue with the tracks since I got her back up and running.
