Help!!! No power at fuel pump!
  • Ga325is
    • Aug 2013
    • 23
    Hey guys thanks in advance.
    1987 325is.
    Had power at pump last weekend but no fuel pump operation. So I replaced the pump today but now I have no power at the pump. I have swapped the relay with a known good one and also checked fuse 11. What else is there? I have no pressure at the fuel rail and no pressure at the filter.
    Really need to get this running ASAP!!!
  • vpilarrt
    • Jun 2006
    • 2096
    Fuel pump doesn't normally get power unless the engine is turning over. However you can jump the relay to make it run otherwise.
    • Ga325is
      • Aug 2013
      • 23
      ok so i jumpped the relay and the fuel pump comes on. Now to figure out why the relay is not engaging... Guess i will have to try another relay. What other reason would cause the relay not to engage?
      • vpilarrt
        • Jun 2006
        • 2096
        Next step is to check for power at the relay pins and continuity of wires:
        Pin 86 - 12V at Start and Run (key On)
        Pin 30 - 12V at all times
        Pin 85 - signal from ECU Pin 3
        Pin 87 - connects to fuel pumps, you have already verified this since the fuel pumps run when the relay is jumped
        • Ga325is
          • Aug 2013
          • 23
          Ok heres what I have so far
          Pin 86 - powered with key in run (verified with test light)
          Pin 30 - powered all the time (verified with test light)
          Pin 85 - how should I verify this? Will there be voltage present at all times?
          Pin 87 - jumped from both pin 86 and 30. Fuel pump comes on.
          So how do I test pin 85?
          Thanks for all your help.
          • Bryanlopez325
            • Jul 2013
            • 115
            I had this issue a while ago check your fuses relays cps and dme and also your connection to the fuel pump after replacing all of that junk turned out it was a bad connection
            • TobyB
              • 5280
              For pin 85, connect your light to +12v and 85. Make sure it's a small test light, not a headlight.
              Then crank. It should light up when you're cranking.
              t
              • boggz412
                • Nov 2013
                • 49
                Check your cps (crank position sensor).
                Sent from my iPad using Tapatalk
                • Jackle30
                  • Aug 2011
                  • 20
                  I had this problem because the harness to the in tank fuel pump was cracked, so continuity was intermittent.
                  Anthracite 2000 M5 - Weekend Whip
                  Schwarz 1988 325is 5Speed - The Daily
                  • Poorboyz
                    • May 2012
                    • 2117
                    Intermittent problems are the worst. I'm currently having one although not electrical.
                    GL
                    Sent from my Galaxy Nexus using Tapatalk
                    Rebuilding since 07/06/2016
                    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                    Poorboyz Feedback Thread
                    • jalopi
                      • 2370
                      Yeah, fuck intermittent electrical problems. What you really need for those is a lab scope (imagine a graphing multimeter)
                      Unfortunately, lab scopes (especially the good ones) are expensive as fuck
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        The only thing you would need a oscilloscope for would be to check for a working CPS. Everything else can be diagnosed with a test light and once you do so, you should be able to verify within a certain amount of doubt that the CPS is good or bad.
                        OP, do you have spark? A bad CPS will also kill spark.
