Rear reinforcements?
  • Brian 89 325i
    • 1450
    Who makes the best BOLT on reinforcements for the rear sway bar? I know of the turner ones and the IE ones but who else?
    Thanks
    Brian
  • Bill 84 318i
    • 1600
    You mean the mounts, and not the trailing arm tabs?
    I like SBI's a lot.
    I'll try (or get Adam) to get better pics.
    • Brian 89 325i
      • 1450
      Oh yeah, I forgot about those, He told me about them when he helped me do my springs/shocks. Ill keep those in mind.
      Brian
      • Beej '86 325es
        • 2639
        Looks like they South Bay essentially is using Turner's design, but solved the problem of installing them by making it two pieces. I heard the Turner ones were a bitch. Personally I still like the Ireland ones, they just look indestructable.
        -Brandon
        '86 325es S50
        '12 VW GTI Autobahn DSG
        '03 540i M-Sport (sold)
        '08 Jeep SRT-8 (sold)
        For sale:
        S50 TMS chip for Schricks
        • Bill 84 318i
          • 1600
          Yeah, I like Ireland's a lot too. Real beefy. But I think it would be a little bit of a pain to drill through those holes when you can't mark them. It'd probably just take a little measuring but still.
          • reelizmpro
            • 9531
            The IE mounts are simple aluminum blocks...nothing special. They're a PITA to install correctly and some of them were not machined correctly leaving either too much play or making it too tight. To remove the bar you have no choice but to go through the trunk... with the SBI's you simply remove the 2 bolts. Turner had teh right idea except the 1 piece design makes it impossible to use the factory hook of the mount for extra support.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
