Check Engine Light problems
  • Siphiro
    • Sep 2013
    • 7
    I have a 1986 325e. I have a check engine light and it is blinking when I turn the car on. I would like to read the code, but the stomp test (5 depressions of the gas pedal) doesn't seem to start the code output. The light just keeps blinking.
    Which version of motronic do I have? 1.0? If so, does that mean there are no codes to read?
    I was under the impression that motronic 1.0 equipped cars do not have check engine lights.
    Thanks!
  • ME30W
    • Feb 2012
    • 811
    Not sure about the motronic differences, but sometimes it takes a couple tries to get the stop test to work.
    I like cats.
    • EyExR
      • Jan 2011
      • 959
      I had to adjust the slack in my throttle cable to get my stomp test to work. If I recall (and somebody please correct me if I'm wrong) but you have to hear an audible click when you release the throttle all the way. Otherwise the stomp test will not work...
      My 325iX DIY Threads:
      Front Wheel Bearing Replacement
      325iX Rear Subframe Bushings and MUCH more w/pics!
      325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
      • reelizmpro
        • 9558
        If you have an ETA engine with Motronic 1.0, which you do unless swapped by a previous owner, you do not have a "Check Engine" light. Make sure you aren't confusing "Check Engine" with "Check" light.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
          No ETA DME supports the stomp test. Nor does the 153 DME as used in 9/86-8/87 i/is/ic cars.
          • autoexpert
            • Dec 2013
            • 1
            check engine code
            Thanks!
            Hey you should buy OBD 2 Scanner to read code, then check engine codes
            Key Fob (keyless entry): http://programkeyfob.com/
            Check Engine codes (Trouble codes) : http://checkenginecode.com/
            :hitler:
