Tachometer not working correctly please help
  • MJTSUB
    • Aug 2004
    • 42
    My tachometer intermittenly will read about 650-700 rpms at idle and then it will drop down to 100 rpms even though the motor is running at the same speed. It wil pop back up to the right rpm when I give it a quick rev and then go back to 650-700 rpms or the 100 rpms mark when it goes back to idle. It doesnt always do it but I would say about 50% of the time. Sometimes when Im driving and I shift around 5500rpms I notice that the tach is going slower than it should from about 4800 to 5500. Anyone have any ideas whats going on? By the way the car is a 89' 325iX. Thanks!
  • James Crivellone
    Head Janitor
    • 6304
    either the tach itself is getting stuck, or the SI Board is failing.
    • MJTSUB
      • Aug 2004
      • 42
      What's the SI board? How hard and how much does it cost to fix? Where is it located in the car?
      • lordofthewaters
        • Oct 2005
        • 714
        The SI (service indicator board) is the solid state board located below your gauges in the instrument cluster. It is an easy fix, just take the cluster out remove the back, remove the board, and reverse.
        As far as price, I've seen them from $40 or ebay to Bavauto for over $100 (I'd recommend these, but someone here may be able to tell you a cheaper place to get them).
        Sarcasm is a body's natural defense against stupid.
        When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
        "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
        Old age and treachery will always overcome youth and skill.
