Timing belt broke causing valves to bend and break rocker arm. recently replaced timing belt as well as the cylinder head valves and rocker arm that broke. When lining timing marks up they were almost perfect except for top cam mark was off by half a tooth, I tried getting it spot on relentlessly, never got it. Put everything back together and started it up. It starts just fine then a few seconds later coughs, bogs down then dies unless you rev it keeping it from completely turing off. Idle is shaky in the 1200 to 500 rpm range till warmed up and stays at a 740 rpm then the car runs okay. The smell of gas is strong, as well as the new spark plug tips are all yellow now, meaning a misfiring problem. Also there is a loud sewing machine like tick sound that gets faster and louder when speeding up. I did a valve adjustment three times to .010 in and it never decreased the sound.
91 325i e30 convertible automatic,timing belt change, starting + noise problems
Could be the valve timing (since it was off a half tooth) or another bent valve.. but i'm going to go with valve timing. Did you rotate the crank by hand twice after the belt install to see if the marks still line up?
Also, the sewing machine noise should be the valve adjustment, did you adjust them cold, hot or what?Comment
:pimp:Timing belt broke causing valves to bend and break rocker arm. recently replaced timing belt as well as the cylinder head valves and rocker arm that broke. When lining timing marks up they were almost perfect except for top cam mark was off by half a tooth, I tried getting it spot on relentlessly, never got it. Put everything back together and started it up. It starts just fine then a few seconds later coughs, bogs down then dies unless you rev it keeping it from completely turing off. Idle is shaky in the 1200 to 500 rpm range till warmed up and stays at a 740 rpm then the car runs okay. The smell of gas is strong, as well as the new spark plug tips are all yellow now, meaning a misfiring problem. Also there is a loud sewing machine like tick sound that gets faster and louder when speeding up. I did a valve adjustment three times to .010 in and it never decreased the sound.
hey brennan2014 Alpine White 335i MSport
(Daily Driver)
Full Mperformance Aero
KW V2 Coilovers
VRSF Catless DownpipesComment
I had the machine shop repair the head, so I don't think there's any missed bent valves, I hope.I adjusted the valves while it was cold each time.
So I guess I'll rip everything apart again and see if I can get the timing marks perfect then post the results.
Hey Cody hahaComment
That's definitely a noise. Did all your valves adjust to spec properly? Sounds like it's just one valve/rocker/whatever it is. It does not sound healthy though.90 325i DD/Track
03 Durango 5.9
Originally posted by e30mpgIt is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.Comment
Older injectors can be noisy - as can misadjusted valves, but those really aren't too bad to do, especially compared to pulling the head, lol.
**Just noticed you posted a video up... sounds like valve adjustment to me. At least 1 rocker is 'loose', like 'popped out six kids' loose.Comment
