Fan clutch question
  • serdar255
    • Feb 2013
    • 395
    Fan clutch question
    When I am driving my cars temperature sticks at the mid point, when ever I take off and give the car gas it goes lower. Does this mean my fan clutch is stuck on? I just replaced my WP and thermostat with my timing belt.
    Thanks in advance for the help.
    image (10) by serdar.gurhan, on Flickr
    PM me for custom shift knobs and stickers!
    Originally posted by marshallnoise
    You ain't done working on a car unless you are bleeding.
  • Poorboyz
    • May 2012
    • 2117
    Your fan clutch is always "on" when the engine is on. To test the fan clutch do the newspaper test. If it stops then you needs a new fan clutch, if it doesn't and tears the newspaper then it's good.
    Does the car overheat?
    GL
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • serdar255
      • Feb 2013
      • 395
      GL
      Shouldnt it turn off when i drive faster?
      • Poorboyz
        • May 2012
        • 2117
        No, the fan clutch is not something that gets turned on and off, there are no wires going to it. If the engine is on...the fan SHOULD be turning.
        Sent from my Galaxy Nexus using Tapatalk
        • FLG
          • Sep 2011
          • 3165
          You have it somewhat correct but it's not an electric on/off
          When the car is at highway speeds, for the most part the clutch is disengaged and the fan is free spinning (maybe not completely but the fan is not spinning at engine rpm) . When the clutch gets warm (car temp goes up) the fan turns with the engine, when cool the fan will free spin/spin slower
          Sent from my SCH-I545 using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • serdar255
            • Feb 2013
            • 395
            Hmmm... so I wonder why my engine temp decreases, do you guys have any ideas?
            • FLG
              • Sep 2011
              • 3165
              Can you better explain? In traffic temp will go up slightly, when moving will go down.
              • serdar255
                • Feb 2013
                • 395
                Well when im on the highway or in motion my temp is at 1/4 or a bit higher. On my e46 what ever im doing the needle is dead straight at half. No fluctuation.
                • FLG
                  • Sep 2011
                  • 3165
                  That's generally how it's going to be. In traffic with more heat your temp might marginally rise. Also could be your fan clutch is worn, get the car to op temp and try to stop it with a newspaper as stated. If it stops, replace the clutch.
                  • serdar255
                    • Feb 2013
                    • 395
                    Thanks, it's good to know i dont have to spend more money :D
                    • jalopi
                      • 2370
                      My first impression was that your thermostat was stuck open, but then I read that you just replaced it... did you get a lower temp stat by accident or something?
