Just picked up an e30. Need some questions answered.
  • kwseattle
    • Nov 2013
    • 105
    Originally posted by rhE-30
    Welcome to E30lyfe. ;)
    Hah, I'm not sure I'm prepared. I know quite a few guys that go to the same university that daily drive theirs, so I should be able to handle it.
    Originally posted by ELVA164
    1. The head unit and OBC do share a fuse, pick up a Bentley shop manual and reference it for the possible culprit. The manual will become a dear friend as time goes on.
    3. The coolant sensor failing is pretty common on these cars, but if all those things started happening at once it sounds more like an electric issue. You can check the ground for the rear lights pretty easily though: remove the rear seat bottom by popping the front edge up on each side, then you should see the ground on the driver's side near the door opening. It'll have a couple brown wires heading to it.
    4. Rough idle could be a lot of things, but intake vacuum leaks are the most common cause. Have a shop do a smoke test to look for leaks and go from there.
    1. Good to know! I'll give my friend a call who has a Bentley manual.
    3. Apparently they were both just replaced. PO worked at a Volkswagen dealership in the service department, he never printed his own receipts. I should ask him to. I'll look into the rear lights as well.
    4. I'll probably be taking it into a shop (some great BMW shops up here in Bellingham, I've heard) to get a tune up and general inspection soon. Good running engine + less chance of failure = peace of mind.
    Thanks again!
    Alpinweiss II 88 325is | M20 | 5 Lug Conversion
    Kyle
    • AndrewBird
      The Mad Scientist
      • 11898
      Have you tired simply oiling your passenger lock? Sometimes they get grit in them and don't function correctly. Try some 3-In-1 or tri-flow in the lock. Apply some to the key as well and insert and pull it out several times.
      • jharrel
        • Aug 2012
        • 130
        if you are not really mechanically inclined enough to diagnose issues on the car i would recommend taking it to a small mom and pop/ small bmw shop and pay an hour or two labor to have the car checked out. But if you can meet a few people locally that drive these cars and know a bunch about them i would get real good friends with them :) good luck!
        • kwseattle
          • Nov 2013
          • 105
          I'll try this, thanks!
          I'd like to call myself mechanically inclined but I'm just lacking the proper tools and shop space. I do have trouble narrowing things down to their origin sometimes, however.
          I'll be taking it in soon. Nothing better than having a fully operational machine.
          Sent from my Nexus 5
          Kyle
          • blunttech
            • 12850
            I think your whirring sound...along with random dash lights coming on sounds like alt on the way out.
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • bmwstudent
              • Sep 2011
              • 1364
              You mentioned a rough spot while turning the wheel. I hate to tell you this but the past three e30's I've rehabbed have need steering column u-joints. Check them before you find out in a turn that they've decided to lock up on you. Not the easiest job but definitely one you want to do. E30's drive terrible after the've been run into a tree or of the road.
              • mkcman17
                • Jul 2010
                • 8240
                Why does everyone seem to think the si board is always the problem?
                Change the timing belt, oil, spark plugs and vac lines. m20s don't need much to keep going.
                1989 LN106 Hilux / 3.0TD SFA
                1974 2002tii / stock
                2002 IS300 / 5spd LSD
                • dnguyen1963
                  • Nov 2011
                  • 2649
                  After about 7600 posts, how many times have you seen people asking about the SI board? The Si board is a very good indicator of something wrong with the system. It can often point you to the right direction.
                  • mkcman17
                    • Jul 2010
                    • 8240
                    Quite often, and I have put together many a-cluster.
                    • kwseattle
                      • Nov 2013
                      • 105
                      So the tach and radio power was a fuse. I wouldn't be surprised if the alternator was in fact on its way out however.
                      It has been idling really rough and having trouble starting, it's also stalled a couple times when idling.
                      Weird thing is, the stomp test gives me a constant flashing, no codes, but the CEL is on.
                      Kyle
                      • kwseattle
                        • Nov 2013
                        • 105
                        About the U joint, can they be refurbished? I actually have a Z3 rack in the mail and I'll have to do the modification to it allow it to fit.
                        Kyle
                        • bmwstudent
                          • Sep 2011
                          • 1364
                          They are designed to be non-servicable but I'm sure someone somewhere has figured out how to source a proper size joint to fit it. However, I have just been sourcing good used ones.
                          • kwseattle
                            • Nov 2013
                            • 105
                            I'll look around. Car is finally in the shop for engine troubles and I asked them to look at the steering as well.
                            I had trouble diagnosing the problem with my engine because the stomp test didn't return any useful info, just a constant flashing. A poor idle, misfiring, and trouble starting could have so many contributing factors.
                            Kyle
                            • RagtopE30
                              • Dec 2010
                              • 1869
                              Does the light that is constantly flashing have the word "Check" on it and located in the center of the cluster?
                              450whp 524 lb-ft 1988 336ic In progress
                              http://www.r3vlimited.com/board/showthread.php?t=250709
                              • kwseattle
                                • Nov 2013
                                • 105
                                No, it's the actual check engine light. After performing a stomp test it will blink, blink again, and then instead of flashing the usual 1XXX Motronic fault code, it just flashes constantly.
                                Kyle
