1991 325 Charging Problem
  • Rajun Cajun
    • 17
    My '91 325 M Technic has a charging problem and the symptons are simular to a post on the DIY as the dash trouble lights blink dimley and the electronics act crazy. I pulled the alt out and checked the brush length and they were 12mm long which is ok.
    I have a brand new battery installed but have the same problem even when fully charged. The alt is a Valeo # 2541114 and I'm not sure where the best place to buy a new one would be.
    Has anyone had this problem or can help point me to a good parts place I would appreciate it.
    Thanks,
    Andy Johnson
  • AndrewBird
    The Mad Scientist
    • 11898
    Measure the voltage at the battery with the car running. Should be ~14v. With the car off, it should be at least 12.5v.
    Even if the brushes are in good shape, the voltage regulator might have died.
    • Rajun Cajun
      • 17
      I did that once but don't remember the exact voltage value but don't think it was 14V maybe 13V.
      I will put the alt back together and measure it again.
      Do you know where I can get parts for a Valeo alt?
      Thanks,
      Andy J
      • Rajun Cajun
        • 17
        I reassembled the alt and had 14.2V with the engine at idle. At 2000 rpm the voltage dropped to 13.2 and headlights on 12.8V
        I checked with my O scope and had no AC ripple voltage so I will assume the diodes are good.
        Time to try and find a voltage regulator. Thanks for the help
        Andy J
        • reelizmpro
          • 9543
          Hey Andy, we spoke on bimmerfest.com. Sounds like a voltage regulator issue. Most of the time, its worn brushes. Check the belt tension as well.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • Rajun Cajun
            • 17
            Hey Brad, how have you been? It's been a while!
            I pulled the voltage reg out and checked the brushes, they were 12mm long. I'm with you though as I think it's the voltage reg.
            Do you know where I can get parts for this Valeo alt?
            Thanks, Andy
