acceleration calculations on a simulator...
  • ptownTSI
    • Jun 2005
    • 1265
    update: 3/7/06
    after going through this again in the morning i must have been a bit foggy in the head. I adjusted the time per shift .35 seconds instead of .50 that it had it at along with re-analyzing the data.
    Originally i thought the m50 swap was the fastest with the E36 trans and 3.25. this is not true. The 3.25 and the e36 trans is going to better benefit higher hp/torque cars. maybe those with the s50 would like this better. or a chip/cam/maf/headers m50.
    but the m50 2.5L is turning out to like the getrag 260, showing about a .10 sec margin over the e36 trans 0-60.
    according to the computer. i know nothing can be perfect, but its interesting to see at the very least.
    i also have done up some excel files where you can plug in the various #'s like tire size, gear ratio, rear end ratio, to figure out your exact speed in any gear.
  • Ray Smoodiver
    • Jun 2004
    • 8809
    email to cilkwurm (at) hotmail dot com please?
    • EtaSport
      • 2853
      How about for using the e30 getrag 260 trans?
      Old and improved:
      • RobertK
        Kicked cancer's ASS.
        • Jun 2005
        • 5864
        Send it to me as well..
        rkadunce@hyndsitetech.com
        • FredK
          • 14762
          Sweet! I believe diffsonline has a calculator with these exact parameters as well. Heh. Anyway did you use the torque curve to calculate the acceleration?
          • ptownTSI
            • Jun 2005
            • 1265
            i used a program called "car-test" its fairly basic but has proven to be pretty accurate for most comparisons. the 1/4 mile times the simulator does always seem a little low. it would say that my old jeep 5.9L would never have been able to run a 14.62 @ 93mph 1/4 mile unless it was making alot more hp than it could have been. all it had was headers, k&n FIPK, exhaust w/ no cat, and a built trans/shift-kit/stall converter.
            yeah i can do the getrag simulation and see what it says.
            • ptownTSI
              • Jun 2005
              • 1265
              ok so i have been tinkering with this a little.
              so far with a getrag 260 and assuming you put 245/40/17's on the back the fastest diff is the 3.73. if you are running 215/40/17's out back then the fastest is the 3.46.
              i'm going to re-do the e36 trans #'s with this updated tire size in the back. this is all 1/4 mile stuff so the bigger tires get better traction.
