Water from Frame Rails
  • markd248
    • Apr 2013
    • 108
    I was underneath my car looking for where water was coming into my driver's footwell and found these two holes on the driver's side frame rail. I know that they are there normally, I was just wondering if people are used to seeing water drip from them. It wasn't a constant stream, more a seeping.
    Also, anybody know a good way to anti-rust coat the frame rails? Some of the coating is gone from contact with my jack stands.
    Thanks in advance
    photo 2 by markd248, on Flickr
    And a little bit closer:
    photo 1 by markd248, on Flickr
  • digger
    • Nov 2005
    • 6198
    my windscreen washer reservoir leaked and water came from the same area. if you park on a hill it happens more
    • dnguyen1963
      • Nov 2011
      • 2651
      Truck bed-liner coating works best, but it is expensive for such a small area. Maybe a can of rubberized undercoating would be sufficient.
      • Bearmw
        • 1323
        I might try spraying a homemade oil based spray mix containing some ATF fluid into the holes. It would probably at a minimum slow down any corrosion already started.
