guys, a friend on mine has an 86es automatic. his speedo quit. if not the sensor, what else would cause the failure? is there a test to determine if it's the sensor? if it is the sensor, do you have to drain the diff to change it?
speedometor question
Tags: None
Don't have to drain the diff, it's located on the side of the diff. Check to make sure the wiring is secured.
Maybe swap with a known good one to check sensor? Also check and the gears, might be stripped? -
Also check fuse 10, 12, and 21.Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
