brakes...
    brakes...
    hey.. my brakes sometimes have the tendency to do a hard grinding sound.. i've narrowed it down to
    ABS going crazy
    or
    Dead pads/rotors..
    I've replaced the pads less then a year ago.. rotors look fine.. any idea on how to check the abs?
    Julien
    Build Threads:
    If its the abs the pedal will pulsate and move towards the floor. Can you feel it in the steering? If so its probably not the abs. As for how to check it, i have NO idea, consult you bently. You do have one dont you? :?
    Brian
      not to jack your thread... but what does it mean when the steering wheel moves back and forth when you brake from high speeds?
        usually warped rotors
        Originally posted by Gruelius
          only happens at low speeds.. it feels like sounds like i'm breaking on ice.. no change in steering wheel or stopping power.. pedal is firm
          Julien
          Build Threads:
            Mine grind as well, but it is only sometimes...normally at low speeds. No steering wheel shaking or anything. Anyone got an idea?
            -Jetta GLi
              Mine grind like hell.
              Then again, half of the surface area of my front pads is worth through to the metal. (Eric, hurry up and send me those brakes!!! jk)
                bump - anyone have an idea for us?
                Julien
                Build Threads:
