Car cranks but no start
  • Hunko
    • Jan 2014
    • 16
    Hey guys I'm pretty new to this forum and just bought my first 318 a few days ago. I bought the car not running and the previous owner said he took out the distributor without aligning it. We'll so I took it home and started to play with it. I have all data on my computer so everything I did is from there. First I set timing at tdc, put in distributor, then new rotor, then cap, then wires in right order. I aligned the distributor and everything looks just like all data is telling me. When I finally went to turn it on it just cranks but doesn't start. Anyone have any idea on what it could be? Any help is appreciated
    Does it have spark? Correct rail fuel pressure?
    • Dj Buttchug
      • Jun 2010
      • 7688
      fuel
      air
      fire
      compression
      time
      Which of the 5 are missing op
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • cgk_iii
        • Dec 2012
        • 616
        If its an m10... Run
        • Hunko
          • Jan 2014
          • 16
          Yes spark and yes fuel. After like 10 seconds of cranking it backfires into the intake it sounds like
          • cgk_iii
            • Dec 2012
            • 616
            Sounds like your timing is off still.. Try rotating the distributor from one side to another slowly. Have someone crank while you turn until you the car fires right up.
            • navid41691
              • Apr 2011
              • 677
              Crank position sensor maybe?
              • SmokeE30
                • 1730
                Sounds like timing is off to me, nothing against all data but maybe check the Bentley manuals procedure and double check
                Shawn @ Bimmerbuddies
                Bimmerbuddies LLC
                717-388-1256
                2971a Roundtop Rd, Middletown PA 17057
                bimmerbuddiesllc@gmail.com
                • Hunko
                  • Jan 2014
                  • 16
                  Got it!!! Moved the distributor alittle and it worked. Thanks guys!
