Steel braided oil lines to oil cooler?
  • Worthy0ne
    • Jan 2014
    • 22
    My inlet and outlet oil lines are leaking and I want to change them over to braided steel. Does anyone know the demnsions for the fittings needed? Is it 18 mm or 22mm? I need more information before I take her apart. And will it work???
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    '89 325I: 2.7 Stroker, CP pistons, H&R springs, eibach sways, ported and polished intake, 4.10's, Step header, Scorp exhaust, BBS shoes. Soon to have MS and 19# injectors:)
    The original hoses lasted over 20 years. The newer hose material is better and should last even longer. You can have the hoses rebuilt for probably less than the SS braid alone will cost. I think I paid between $20 & $30 for the last set.
    • Worthy0ne
      • Jan 2014
      • 22
      Thanks for the input jlevie. I really want to go to braided steel route. I'm not worried about the cost of the lines so much.
      • ELVA164
        • 4861
        Are you looking for appearance from the braided steel? Other than that, they don't provide much benefit on a road car. Other than that, you could make your own lines to fit.
        • TobyB
          • 5280
          I brazed AN ends onto the stock steel hose ends and made my own. Took a couple of
          hours and used parts I already had lying around. Worth it? Sure, since I didn't
          have to actually buy anything. Only real gain is that if one pops, it can be re- made
          at the track. But then, they NEVER pop...
          because racecar?
          t
          • Worthy0ne
            • Jan 2014
            • 22
            The main purpose is for looks. And in the future if it breaks I'll still have line left over to replace.
            What was the measurement for your an fittings Toby?
            • TG Goose
              • Jul 2011
              • 234
              I used metric 22mm to -8 JIC Adapters on my setup. Swapped out the stock cooler for a much larger B&M cooler. Using aeroquip pushloc hose and fittings.
              Posted via MotoX
              ______________________________________
              1984 LSB 318i - Sold
              1986 325i - Motor Swapped Track Car Project
              1995 318ti - Sold
              1999 540iA - Daily Driver
              • TobyB
                • 5280
                I used the stock metal ends off the stock hose, and brazed AN-8 fittings onto them.
                2 straight AN-AN hoses later, all done.
                Almost ghetto, but better (I thought) than trusting the 25- year- old original rubber.
                t
                • Worthy0ne
                  • Jan 2014
                  • 22
                  I ended up buying replacement hoses. I will be using the old lines to tinker with to see what is the best way to add the braided steel. TG, do you have a part number or a location for the 22mm to -8an fitting? I cant find one anywhere.
                  • efficient
                    • Feb 2012
                    • 3312
                    i was thinking of doing it this way. any suggestions?
