Steering Column / Wheel Q
  • cwatt
    • Oct 2012
    • 275
    Hey R3v,
    The previous idiot (owner) stripped the threads on my steering column for bolting down the wheel. Since I need to replace that, it has me wondering if I could install an air-bag wheel in the vehicle (air-bag removed). I would be removing the electrics, but I'm thinking this:
    Creative mods to a column would allow you to mount that steering wheel, but it would require invention and addition of electronics to have any of the steering wheel mounted controls/displays work.
    • jalopi
      • 2370
      I don't know man... sure, it looks good in that car, but I think it might look a bit too 'futuristic' in our cars.
      On a side note, have you tried saving the column threads with a die? Or are they just that fucked up? You'd be surprised at what a good die and steady hand (read: proper initial placement of the die) can bring back.
      • cwatt
        • Oct 2012
        • 275
        Hey, you must have missed that I don't intend to use the electronics, but that's good to hear about the mounting. My primary concern 'electrical' wise is the horn...
        Threads are totally f-ed. Wheel was probably installed with an impact gun.
        Re: aesthetics, I have something really interesting planned for the interior.
          By creative mods to the column I mean getting a column/shaft from the car the steering wheel came from and modifying it or grafting part of it onto the E30 column/shaft.
          • E30NJ
            • Aug 2013
            • 921
            Are the splines on the old column the same as the new ones on this steering wheel?
            • Madhatter
              • Oct 2004
              • 966
              they won't be.
              If the threads are totally destroyed and you can't clean any of it up, you are going to have to swap out the column.
              Just a little project im working on
              - http://www.lse30.com -
              • TobyB
                • 5297
                Or find a die (maybe SAE?) that will cut new threads onto the stub...
                hth
                t
