Oil Cooler Thermostat
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    I recently rebuilt my oil filter/cooler housing and when I put it back on the first time oil poured out where there oil cooler thermostat was. I used all new seals so I couldn't figure out what went wrong.
    In a hurry to get my car back on the road I removed the oil cooler thermostat and put it back together without it. So far no leaks and the car runs fine. I guess what I'm getting to is I want to know if there are any known problems to running my car without the oil cooler thermostat?
  • arsevader
    • May 2005
    • 1025
    Cooler oil...
    • RobertK
      • Jun 2005
      • 5864
      Originally posted by arsevader
      Cooler oil...
      This might sound stupid but.. are there any side effects I should be aware of???
      • arsevader
        • May 2005
        • 1025
        I wouldn't think so. It'll allow all the oil to pass through the cooler all the time rather than when the thermostat opens.
        • NC325iC
          • Mar 2004
          • 6565
          theres a thermostat?!
          • arsevader
            • May 2005
            • 1025
            Yeah, it's in the oil filter housing on the 'i' cars.
            • PeaveyBassist
              • Sep 2004
              • 3511
              It will keep your oil from heating up quicker. Cold oil = higher oil pressure. Not really a good thing but if you keep the rpm's down for a long time it might be ok. I don't even know if the oil would get all the way up to temp if the thermostat was open the whole time. You should probably get that fixed.
              Will
              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
              Welcome e30 (brilliantrot '90 325is) 12/23/06
              DaveCN = Old Man
              My signature picture was taken by ME! Not by anyone else!
              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
              • AdamF 88iS
                • 2051
                Oil doesn't lubricate at it's full potential if it's not within it's operating temperature range. Too hot AND too cold are both no good.
                Adam Fogg- '88 M3
                Common sense- It's the new 'gifted'
                • RobertK
                  • Jun 2005
                  • 5864
                  I live in the south so I would think that the oil being to cold shouldn't be a problem.
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    That has nothing to do with it. As Adam said, oil needs to be just the right temp. Too cold or too hot is baaaad. And thats oil temp, not ambient temp.
                    Will
                    DaveCN = Old Man
                    • RobertK
                      • Jun 2005
                      • 5864
                      Spoke to a BMW mechanic friend about it. His remark was that it shouldn't be a problem it will just take a little longer to warm the oil up.
                      • AdamF 88iS
                        • 2051
                        Operating temp for oil in the motor is 200-210*F. I don't think being in the south would have much to do with that.
                        Adam Fogg- '88 M3
                        • Gus
                          • Jan 2004
                          • 285
                          did you crush the copper washer? i have done this before...a new one not expensive
                          JUNGL3
                          1990 "333i" Sport
                          • RobertK
                            • Jun 2005
                            • 5864
                            No.. actually the replacement one is now made of aluminum.
                            It was leaking from the thermostat housing though I'm begining to think that I might have just punched the rubber gasket. I tried the C-clamp method ofinstalltion but that was a nightmare.
                            BTW.. what is the correct way to reinstall the oil cooler thermostat. When I took it apart the first time it looked as if someone had already tried to rebuild it and did it wrong because the spring was loose and had no tension on it.
                            • AdamF 88iS
                              • 2051
                              If the spring was loose they probably left the piston out of it.
                              It is a common leak, there is a new plug and circlip design avalible from the dealer to fix it.
                              Adam Fogg- '88 M3
