Valve adjustment on AT
  • eliasmavs99
    • 58
    Doing a valve adjustment on a manual Trans. isn't too hard. But I don't know how to turn the cam in an Automatic 325i. Does anyone know how to do this. Thanks in advance.
  • Jordan
    • 12916
    I'm sorry, how is it any different?
    https://mtechniqueabs.com/
    • eliasmavs99
      • 58
      Sorry for not clarifying Jordan. I turn the cam in the manual by putting the car in 5th and pushing the car backwards until the lobes are out of the way. I never learned it the other way.
      • Jordan
        • 12916
        rofl....
        or you can just put it in N and put a 22mm socket and ratchet on the crank bolt and turn it over manually like a normal person
        • eliasmavs99
          • 58
          where is this bolt? Is it under the cap and rotor? I knew there was another way.... Thanks Jordan
          • Jordan
            • 12916
            Originally posted by Jordan
            crank bolt
            Is that really too complicated for you to figure out on your own as to where it is?
            • eliasmavs99
              • 58
              You're right. I'll remember that next time I think about turning to the forums to ask a question.
              • Jordan
                • 12916
                I answered your question. It is not my fault you are apparently not smart enough to figure out where the bolt on the crank is.
