anything left out? (tune-up list sorta)
  • PУCCKAЯ_e30ka
    • Jan 2006
    • 1226
    T-belt
    P.S. the pads, belt, some other small stuff isn't in the pic.... other then that :p
    t-belt tensioner
    waterpump
    thermostat
    all the hoses
    4 rocker seals (can't rem. the exact name)
    cam seal + o-ring (in process of ordering)
    valve cover gasket
    anything else?
  • e30Matt
    • 5077
    Plugs. Bosch Supers or Autolite #64s.
    • turnofftheradio
      • Apr 2005
      • 448
      cap/rotor/wires?
      coolant
      oil
      oil filter
      want to do your hoses that go to the thermostat housing and water pump?
      depending on the brand, some tensioners don't come with the pin and spring for the tensioner
      maybe do the rest of the belts
      I seem to turn every little job into a large order from bma...
      • PУCCKAЯ_e30ka
        • Jan 2006
        • 1226
        is the 32mm wrench the only "special" tool needed? I can't exactly remember, but either bav. autosport or bmp design sells special 32mm wrench just for this job, is it worth it? Or I'd be better off w/ one from sears or somthn?
          • 34839
          I've always been able to do it with a regular 32mm wrench; it's tight and I have to move the coolant pipe that goes behind the fan first, but it always works. of course they probably cost about the same so you may as well get the special tool..
          • Simon S
            • Oct 2004
            • 3758
            beer
            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
            • PУCCKAЯ_e30ka
              • Jan 2006
              • 1226
              Originally posted by Simon S
              beer
              russian people simply can't work on cars sober... there is no such a thing as russian sober mechanic...
              Tomorrow I'm going to sears get some long**s extentions, 32mm wrench, some small other stuff... the big day is coming!
              P.S. is there any noticable difference when the engine will have new t-belt? just curious..
              • e30Matt
                • 5077
                If there is, you did it wrong. :)
                • HST
                  • Jan 2006
                  • 757
                  For the 32mm, got to your local bike shop / sporting good stoe and get one made for a bike. They are alot thinner and easier to use to get the fan clutch off.
                  Originally posted by KingB
                  Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                  • PУCCKAЯ_e30ka
                    • Jan 2006
                    • 1226
                    I've got all the parts.... now it's just 32mm wrench and coolant is needed to start the process!
