M20 cold weather starting question
    I recently purchased a 1987 325e and I'm just curious about something the vehicle does on particularly cold days. When I turn the key to crank the engine there is an odd sound from the engine bay (sound reminds me of a fuel pump priming, but louder and in the engine bay) and it runs for about 10-15 seconds. During that 10-15 second time frame turning my key to start won't engage the starter and turning the key off does nothing to stop the noise. Once it stops on its own, I turn the key back to start and it fires right up.
    I've read quite a bit into the ICV being the source of the noise but being as that I'm fairly new to this engine I'm just curious if maybe it's not an issue at all and something that is meant to happen in cold weather conditions. Times when the car has done this it has been sub 20 degrees fahrenheit.
    Thanks for your time,
    Jeff
    Very odd. I would have someone else turn the key while you listen with the hood open to see exactly where the noise is coming from.
    That is not normal.
    90 325i DD/Track
    03 Durango 5.9
    Originally posted by e30mpg
    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
      Ok that answers my main question about normaility. I'll have to do what you suggested and listen and locate while somebody starts the car. Thanks for the input I'll update if and when I find anything out.
