Fan hitting radiator.
  • Worthy0ne
    • Jan 2014
    • 22
    I just completed a timing belt change. This includes a water pump replacement, and accessory belts. But now my fan is hitting the radiator. Has anyone came across this before? Will a fan delete cause more problems?
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    '89 325I: 2.7 Stroker, CP pistons, H&R springs, eibach sways, ported and polished intake, 4.10's, Step header, Scorp exhaust, BBS shoes. Soon to have MS and 19# injectors:)
  • Tom.
    • Sep 2012
    • 121
    I would check the condition of the motor mounts.
    I would not delete the fan.
      If the fan is hitting the radiator fins, the radiator isn't correctly installed or you have some oddball (wrong) water pump.
      • TobyB
        • 5263
        ...or your car ran into something hard and wasn't pulled back all the way.
        More common problem with 2002's...
        t
        • ELVA164
          • 4861
          I've seen where a car was hit in the front and it crunched the chassis rails a bit. Even though the radiator core support got pulled forward, it moved back again after some time and the fan hit the radiator again. Any signs of damage in the front end?
          • navytapaul
            • 615
            Mine did this when the motor mounts went. Like Tom said, I'd check those and get some hd mounts if they're bad.
            Sent from my SAMSUNG-SGH-I727 using Tapatalk
