My M20 Tranny is dying - can I install a E36 Tranny?
  • 65Matt
    • 172
    The manual transmission in my 1989 325i is having problems:
    1.I have to be very careful when shifting from 2nd to 3rd or it grinds. By careful, I mean push the clutch in all the way, hold it for a second, match revs, and baby it into 3rd.
    2. It's now popping out of first gear as I'm trying to get the car moving from a stop. (Very violently)
    3. The shifter is very sloppy.
    Can this tranny be fixed, or is it even worth it?
    Since people swap in the M50/S50 motor and keep the M20 transmission, does that mean I can just install a M50/S50 transmission with my M20 motor? (When I had my 94 325is, I loved the way the transmission shifted.)
    If this swap is possible, what would I need?
  • JRowe
    • 352
    Your current tranny is not worth fixing. Find a replacement. You can use an e36 tranny, but it will require a different driveshaft and perhaps some other work. I'm not entirely sure becaue I've never done it. I'm just going on what I've heard on this board. I'm sure someone who has done the M50/s50 swap will chime in and answer all questions.
    I would advise you to just find a good, used m20 tranny. Unless your planning an m50 swap in the future, there is no need to change trannys.
    • rscheiring
      • Jan 2004
      • 1014
      and the E36 tranny isn't exactly famous for being bulletproof...
      A great pleasure in life is doing what people say you cannot do- Walter Gagehot
      • 325 eta
        • 472
        i think you can use the same driveshaft, my tranny does the same in 2nd and 4th
        • Rob
          • 8166
          the e36 box is a lot more complicated, therefore more expensive to fix if it breaks. Find another e30 box. There was a few in the r3v classifieds recently
          BEERTECH
          • Digitalwave
            is a poseur
            • 6299
            E36 boxes also have different ratios, so a new diff would be in order.
            RISING EDGE
            • BahnE30
              • 1050
              6 speed in a m20 e30 would be tight as hell though
              • Stu Mc
                • 4083
                True. 3.25 or 3.46 would fit the bill for a 325i, but you might want to hang onto the 3.73, would be a blast.
                However, why do this? The feel of the M20 tranny is great, and you'll appreciate it more during high performance driving. The Getrag 250 (E36 318/325) and the ZF 310 (E36 M3) are more prone to downshift overrevs as well.
                I love the M20 tranny's. I'd suggest getting another one if I were you. Used, they run about 1/2 what a used M50 tranny will.
                • Brian 89 325i
                  • 1450
                  DOG LEG DOG LEG DOG LEG. Or another run of the mill G260.
                  Brian
                  • BavarianBimmer
                    • 951
                    Can somebody explain those codes like Getrag 240 and 260 ??
                    Any help would be great :roll:
                    1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                    1997 E36 328iT
                    1990 E30 325iT 24v SOLD
                    1989 E30 325i 2.7i M-Technic II SOLD
                    • BS87
                      • 1606
                      240s were in the 4 cylinders, 260s in the 6 cylinders (i think)
                      • M-technik-3
                        • 18946
                        Matt, why does it grind? Have you checked the fluid levels? Are the synchros worn? What are the symptoms?
                        You can find trannys out there as little as $50 to $750 so spend some time and find a good yard.
                        • Stu Mc
                          • 4083
                          Getrag 240 --->M42 (in E30)
                          Getrag 260---->M20
                          Getrag 250---->E36 318/325
                          ZF 310----->E36 M3 (and 328 i think)
                          I do not know what the M10 cars came with, but I recall their being a ZF tranny available. Bill may know.
                          • JPbmw
                            • 466
                            what about the one in the first E34s that came out?
                            The ones that still had the M30 in them
                            '86 325
                            • Stu Mc
                              • 4083
                              Probably the Getrag 265 that was used in the E28 M30 cars.
