Fuel pump replacement
  • dougie30
    • Apr 2012
    • 1708
    Ok so I have a 86 325e with the in tank and external fuel pumps and one of them is shitting the bed (maybe bolth).
    Ill be driving at a stedy pace going 65 at 3k and my car will bog out and then pic back up. It does this quit a bit and I hear a loud buzzing comi g from near where my ful pump is located.
    So I was wondering which one would be causing this? I know the internal one pumps the fuel but im not sure about the external how it works? Maybe this one could be slowly dying out?
    Sent from my SPH-L710 using Tapatalk
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • dougie30
    • Apr 2012
    • 1708
    Or would it just be easier to replace bolth pumps with the walbro 255 intank one?
    I was reading up on this and it seemd fairly easy im hust not sure what I should to about the external pump?
    Just use a duel barbed fitting inplace of it?
      The noisy pump is almost always the external high pressure pump. It will make noise if worn or if it is having to work too hard from a clogged filter or dead in-tank transfer pump.
      • dougie30
        • Apr 2012
        • 1708
        Just went to auto zone and they said the internal pump is 149$ with the whole assembly and the external is 150$ im not sure wich one I should get what is the best way to test them?
        • TobyB
          • 5296
          I like the in- tank conversion myself, but just because it's easier to service. Converting IS
          a big pain, because you have to replace and re- route the pressure and return(?) lines.
          The way to test them is to put a fuel pressure gauge on it.
          But you can test the in- tank pump by unhooking it and letting it dump into a coffee can- if you get a healthy flow of fuel, it's OK. You have to crank
          (on some (most?) cars)
          to get the pump to run.
          And I'm with Jim- check for junk in the screen and tank and replace the filter!
          hth
          t
