So yesterday I had a brand new Magnaflow cat installed (weld in application), and after when I tried to start the car up it takes 3-5 long cranks compared to my regular start ups. The battery seems to be healthy what else should I check for. I have a fuel filter I need to replace and will do it soon, what could it be also.
Takes 3-5 sec to start car
'99 e46 323i - wrecked
'87 e30 325iS - sold
'91 e30 325i - sold
'89 e30 M3 - fun car
'09 e91 328i - sold
'97 impreza - rally car - flipped
'08 impreza - new rally car
'01 996 tt - more fun car
'82 Ford f350 - work truck
yea i figure if it was a vaccum leak or any of the above my ca owuldnt idel or be able to accelerate normally. Battery is about 2 years old maybe Ill swap it out and give it a try!
Also, if you got 12V while the car was running it's no good. Running voltage should be in the 13.5-14.2V range.Interested in vintage cars? Ever thought about racing one? Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
Elva Courier build thread here!Comment
If this is the case, it's probably not a battery issue, though. A charged battery is like 12.6V. 12V is still like 50% charged I think.
Either way, I doubt a battery would cause a long crank unless the cranking was noticeably slower than before. Remember to fix the cause, not the symptom.'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
