So I get a knocking noise that I feel in the trans well. Its not the flex disk. Had the car up on the lift and we checked everything we could with out dropping the exhaust and it was all tight as I just had the whole car apart and all of the mounts and the whole exhaust is brand new. It doesn't make the noise all the time which is frustrating when you're trying to diagnose something. The times it WILL make noise is when I'm going highway speeds over bumpy road, highway speeds or occasionally right after I shut the car off as it's powering down. The drive shaft was replaced not that long ago from Driveline. Can a bad center support bearing make that noise? And if so why wouldn't it be doing it all the time? That's the only thing I haven't checked yet. Any ideas? Thanks everyone!
Let's play the mystery noise game!
sigpic2000 323ci
1987 325is super etta
1988 M5
2000 M5
1989 944 turbo
1989 325isTags: None -
I know this doesn't have anything to do with your problem but before replacing your driveshaft, do you get a clunking noise from the rear when shifting gear? I'm trying to solve mine, hopefully you can help me instead. -
Center support bearing can cause that sound, but in my experience it's going to typically be more when you are accelerating.
Are you sure one of the exhaust hangers isnt loose?1987 Delphin 325e Sedan - Natalie
1990 325i 24v
1997 Chevrolet K1500 Crew Cab 4x4 - The CenturionComment
Do you guys feel this noise is external or internal to the transmission? Mr.Vang, you said you get the noise when shifting gears... all the gears?sigpic
Rebuilding since 07/06/2016
Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
Poorboyz Feedback ThreadComment
sigpic2000 323ci
1988 M5
2000 M5
1989 944 turbo
1989 325isComment
sigpic2000 323ci
1988 M5
2000 M5
1989 944 turbo
1989 325isComment
anyone? anyone? Its driving me nuts.sigpic2000 323ci
1988 M5
2000 M5
1989 944 turbo
1989 325isComment
I had a problem similar... a knocking i couldn't figure out. Only would happen over bumps! Dove me nuts!!
Ended up being the transmission cross brace wasn't completely tight. You know, the black bar that holds up the back of the trans??
Kinda a scary thought once I finally figured it out! Only a matter of time before it would fall hahaha!
I know you said it came apart with all new mounts... But maybe shit didn't get tightened..
Just my 2c
1988 325is - Track Toy
1986 325e - Daily Driver
Lovin the e30'sComment
Checked...it was tightI had a problem similar... a knocking i couldn't figure out. Only would happen over bumps! Dove me nuts!!
Just my 2csigpic2000 323ci
1988 M5
2000 M5
1989 944 turbo
1989 325isComment
@ Vang-- your diff mount is probably loose or worn. @ LiveFast--Exhaust may seem tight but could be striking body when traversing bumps, if it's very close to the body. Sometimes, even a car that only weighs 2700 pounds can cause rattles we can't easily replicate with our hands. However, you said it also makes the noise AFTER you've turned the car off, which should eliminate any moving parts like a center support bearing.Comment
