@ Vang-- your diff mount is probably loose or worn. @ LiveFast--Exhaust may seem tight but could be striking body when traversing bumps, if it's very close to the body. Sometimes, even a car that only weighs 2700 pounds can cause rattles we can't easily replicate with our hands. However, you said it also makes the noise AFTER you've turned the car off, which should eliminate any moving parts like a center support bearing.
It will make the noise occasionally AS I turn the car off. Can't replicate the sound after it's off.
