Fuel pump runs non-stop when ignition in "on" position *solved*
  • Ether-D
    • Sep 2011
    • 2838
    1992 m20b25, eaton m90 supercharger, and Whodwho ms2 has been running great for 3 weeks since I installed the s/c. …but…
    Usually, when I turn the ignition to the on position, I hear the fuel pump run for a few seconds and then it stops. Lately, it won't stop running and the car won't start. Sometimes it will turn itself off and when it does, it starts fine. Relay? Pump? Any ideas guys? Thanks in advance.
    Originally posted by Andy.B
    I was born on 3/25…
  • FLG
    • Sep 2011
    • 3165
    sounds like a relay issue, could try swapping the dme and fuel pump relays and see if it still does it.
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • Ether-D
      • Sep 2011
      • 2838
      I'll start out in the morning with that. I have the pump out to look it over. Thanks bro.
      I was born on 3/25…
        • 34844
        You cant swap the FP and main relays, they are different.
        • Ether-D
          • Sep 2011
          • 2838
          Does anyone know why the fuel pump turns on for a few seconds then turns off under normal conditions? Does it have some kind of pressure switch?
          I was born on 3/25…
          • Ether-D
            • Sep 2011
            • 2838
            Solved. It was the white, 5-prong relay in the bank of three on the strut tower, driver side. You were on to something FLG. When you turn the ignition to on, it should go "click…clickyclick" then the fuel pump will shut off. Mine was just clicking once, and no shut off.
            I was born on 3/25…
            • FLG
              • Sep 2011
              • 3165
              Glad you solved it. Yeah just remembered the main relay is 5 prong and thing FP relay is 4?
              Sent from my SCH-I545 using Tapatalk 2
              • Ether-D
                • Sep 2011
                • 2838
                Correct. Thanks again.
                I was born on 3/25…
                • gettinscurvy
                  • Jun 2013
                  • 164
                  So it was the main relay that needed replacing?
                  My car just developed this issue yesterday, Ignition "ON", fuel pump runs non-stop, whereas last weekend it was operating as designed (Ignition "ON", fuel pump runs for 1-2 seconds).
