Auto Trans indicator
  • chick
    • Dec 2008
    • 21
    Folks, my 89 has an auto trans, and I can't find a part number for the bulb that illuminates the gear indicator. RealOEM and BMW Parts guys can't help. It has a black plastic base, push in type not the same as in the cluster. Anybody know the PN for this?
    "I'd rather die happy than not die at all" Robbie Robertson, W.S. Walcott's Medicine Show.
    1989 325is
    1995 525i
  • DesertBMW
    • Aug 2011
    • 1033
    osram 2721
    two wires to it are known to brake, bulb may be good
    • jperris
      • Feb 2014
      • 31
      +1 on the possibility of broken wires. I took mine apart a couple weeks ago and found that to be the case.
      Anyway, the bulb is BMW p/n 63-21-7-167-000. Listed in the parts catalog under 61.35 for the shift light bulb. The same bulb is used for the heater control panel and listed under 64.20.
      1989 Bronzit 325i
      • e30trooper
        • 11576
        #thatautolyfe , pull it all off and replace the bulb along with checking wires. Should be a easy fix.
        • chick
          • Dec 2008
          • 21
          Thanks for all the info. I will check it out this weekend.
          1989 325is
          1995 525i
