Rocker arms.
    Rocker arms.
    Anyone ever break a rocker arm and drive without noticing it?
    "Having won more road races than any other model in history, the E30 M3 is considered by many to be the world's most successful road race car." - Simply put, E30s kick ass.
    I broke a timing belt and didn't notice it for a month... ;)
    You'd notice a lack of power and probably some valvetrain noise too.
      Well, no lack of power, but my valve tick seems to have gotten louder after a spirited donut session. Probly just need to adjust them, it's about that time again.
        mine recently got louder, but then again, after i changed my oil (2000 miles ago) i never filled it up. with a filter change, how many quarts should be used? i think i only used 4 or 5. but that still wouldnt explain the sudden valvetrain noise increase. maybe its my head playin tricks on me?
        Claus Luthe is my hero.
          If you broke a rocker the motor would only run on 5 cylenders. The massive misfire would be pretty hard to miss.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
            Yeah thats pretty much what i had figured, although the increased noise is not my imagination, it's quite noticeable.
              You should always change your filter with an oil change, and i use 5 quarts every time, let the engine burn off the small amount of excess. I recently changed my oil, 232,000 miles, i used castrol GTX high mileage, and also ran a deposit cleaner through. Since i used a slightly heavier wieght (20w50 as opposed to 15w50) it hushed up the valves pretty well, until the other night.
