Where can I buy this actuator?
  • rammstein
    • Jul 2009
    • 367
    It has to be this one- the one I got from the junkyard looks totally different. Apparently it is an anomaly with the rear locks on 91 e30s. HALP!!! And given the difficulty of this mess, I will not want a used one- I never want to do this again. NEW!!!
    E30 M52B28
  • Semblance
    • Jan 2011
    • 433
    The part number is right there. Google says:
    http://parts.bmwofsouthatlanta.com/p...261394368.html
    '89 lachssilber vert - Frau Blücher
    '84 alpine 2dr - gone to the great beyond...
    '00 titanium 4dr e46 - bricked
    • rammstein
      • Jul 2009
      • 367
      I saw that, but my concern is when you go there, it says that part is #27 on the diagram to the left, and that part does not look the same at all. Would you assume that they just have a bad diagram?
      E30 M52B28
      • Semblance
        • Jan 2011
        • 433
        I see, so you're worried that even though it's the same part number, it might look or be different and not work? Not sure why they would issue a different part with the same number (of course that's what GM did with the cobalt ignition...). That page does show three part numbers for the same part. If you want new, I'm not sure there will be any way to find out without buying one.
        • jeffnhiscars
          • Jun 2011
          • 6011
          After having swapped out every actuator in my Cabrio (yes it was a total bonehead move that caused it) I can tell you the bodies are all colored coded.
          They also have an over center cam in them so if you cant move it by hand after removing it then its probably toast.
          Alice the Time Capsule
          • bmwm42
            • 6300
            I have one
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
