Deleting third brake light...
  • Bimmerfanatik
    • May 2004
    • 5349
    So the cabby has a nice coupe/sedan trunk lid on it, thereby effectively deleting the unsightly third brake light thrown on the e30 verts. Now my problem is, the check control panel thinks there's a brake light out since the third brake light isn't plugged in. How can I loop/bypass the third brake light wiring to make the check control be light-free? :)
  • wastedincome
    • Aug 2004
    • 906
    Hook the light up and leave in the the trunk ;)
    Wastedincome420@yahoo.com
    CURRENT STOCK LIST:
    00' e38 750iL HighLine=Highway Queen
    92' e30 318 vert=Aint going anywhere
    91' e34 535iM=Aint going anywhere
    91' e34 525iA=For parts
    92' e34 535iA=For parts
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      Find the resistance of the bulb with an ohm meter
      Then solder that equivalent resistance in the wires where the brake light would go...
      Do the cops notice that you dont have the 3rd brake light u think?
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • DaN
        • 1265
        Is there a connector with 4 wires going to the 3rd light assembly?
        If I'm not mistaken, if you jump pins 3 and 4, both wires green/black. That should trick the system.
        I haven't tried it, im just looking at a diagram.
        • wastedincome
          • Aug 2004
          • 906
          That would be the best way to do it. But too much work IMO
          I doubt cops would notice but I wouldn't do just cause the fact I'm ALWAYS worried bout gettin rear ended
          CURRENT STOCK LIST:
          • Bimmerfanatik
            • May 2004
            • 5349
            Thanks to Mark, for providing the hack way ;)
            anyways...I don't know where the wires are, and don't have a third brake light ;)
            • wastedincome
              • Aug 2004
              • 906
              I learned from the best ;)
              CURRENT STOCK LIST:
              • DaN
                • 1265
                Do you know where the connector is?
                I think my way will work.
                • James Crivellone
                  Head Janitor
                  • 6301
                  Just to backup DaN, screw the resistor portion, just jump pins 3/4 at the brakelight.
                  You can view the schematic here to verify my suggestion if you wish.
                  • Bimmerfanatik
                    • May 2004
                    • 5349
                    Dan and James, I thank you. Just gotta find the plug now... ;)
                    • DaN
                      • 1265
                      No problem, let us know how it works out.
                      • Dave
                        E30 RAT
                        • 11675
                        Left side of the trunk - its kinda near the hinge - you'll likley need to pull the lining on the left side back to get to it. Its a wire with (I think) a two prong/hole plug (obvioulsy unplugged) to it IIRC.
                        Current Cars
                        2014 M235i
                        2009 R56 Cooper S
                        1998 M3
                        1997 M3
                        • NC325iC
                          • Mar 2004
                          • 6565
                          old thread bump.
                          did you ever do this?
                          i just replaced my trunk lid with an is lid i will try this tomorrow
