throttle cable install diy / M42
  • jdt10768
    • Feb 2013
    • 484
    looking for a diy before doing this so I can save time and do it correctly the first time through. Anyone have a detailed diy? thanks
  • roguetoaster
    Biggus Tippus
    • 7829
    Well, a Haynes manual would tell you to remove the cable, and that installation is reverse of removal.
    The truth is that you remove the cable from the TB with some twisting to pass the end retainer through, then disconnect it from the pedal assy. Pull the cable through from the engine bay, and really do the reverse to reinstall.
    • jdt10768
      • Feb 2013
      • 484
      so basically, do it
      • roguetoaster
        Biggus Tippus
        • 7829
        Yes, you'll figure it out quickly enough.
        • AndrewBird
          The Mad Scientist
          • 11898
          The hardest part is getting to the plastic clip that is in the firewall. You have to squeeze it with pliers so it compresses and will then fit through the hole. Look at your new cable and it will make more sense.
          • jdt10768
            • Feb 2013
            • 484
            did you have to break the old one to get it out?
            so, long skinny needle-nose pliers?
            • roguetoaster
              Biggus Tippus
              • 7829
              Probably, pliers and a screwdriver ought to get the job done.
              • jdt10768
                • Feb 2013
                • 484
                Quick pop with long flathead screwdriver and rubber mallet breaks old clip for removal. All good and installed. Minimal swearing involved. Def worth the time, and a cheap fix for the broken barrel adjuster
