Hey guys,
So I just finished up my engine swap, but was unable to figure out my turn signal problem which I had before the swap. The problem is both turn signals work fine when my hazards are on. They also blink at the correct rate when the stem is moved up or down just a bit. But If I go all the way up or down to lock it into left blinker or right blinker, the turn signals will not light up at all.
Its like the stem has a sweet point and I have to jiggle it manual to turn them on, it wont just do it by itself.
Recap:
1. Turn signals work fine with hazards
2. Turn signals blink at the correct rate when stem is moved up and down and hits the "sweet spot". Wont work if its under or over it.
Am I just having a switch problem? or has this happened to anyone else? Sorry if I am not being very clear, I'm trying to explain it the best I can.
Also I tried to do a search but most of the searches that come up are for blinkers that don't work completely or blink to fast.
Thanks in advance.
Recap:
Thanks in advance.
