OBC doesn't display speed or milage
    My 13 button obc will not display things like speed, range or mpg (display reads ----) but the clock, temperature, and code functions work fine. I have no problems with my instrument cluster. Any ideas what could be wrong or things I can try?
    1988 Alpinweiß 325i 4D 5SPD
    I removed the climate control/radio panel to get a better look at the connector... Everything looked fine except the green connector body was broken (no broken wires).
      I just tried swapping in a known working computer from a 91 convertible and it worked. When I tried my unit in the vert it gave me a PPPP code... When I put it back in my car the error is still there. I tried pressing CODE and the reset button without any luck so I'm letting it sit disconnected for a little bit.
      I reinstalled the working obc in the vert and it continued to work fine.
      Is my computer toast, or it it possible my problems are due to a bad code plug in the back?
        The test you did confirms that your OBC is dead.
          Perhaps...
          but... I just removed the code plug from the back and re inserted it and now it doesn't give me the PPPP error anymore... Still no reading on speed/mpg etc.
          I just picked up another one on ebay... I'll try swapping the chips when I get it to see if that fixes it.
            Hi, you are welcome to this forum site.
            i do not have idea about this,
            i will suggest you to meet expert of the car
            _________________
            Top Ten classified website
