Brake Switch Keeps Blowing
  • blizake500
    • May 2014
    • 424
    Thanks in Advance!
    When I go on long trips with my 1990 325is, sometimes my brake switch goes out so i go to autozone and put in a new one. Well last time it went out, i went to replace it and it was too hot to even touch. So i let it cool down a bit and when i looked at the two copper connectors, one was faded real bad and the other was fine. And the one that was faded, the plastic around the copper connector was melted. Whats my problem??? Please help! I dont wanna keep buying brake switches
  • Todd Black 88
    • Oct 2007
    • 3449
    You have too much current in that circuit. Probably due to a short, or wrong bulbs used.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • blizake500
      • May 2014
      • 424
      It could be do to a wrong bulb????
      • blizake500
        • May 2014
        • 424
        What is the correct bulb for the brake lights???
        • reelizmpro
          • 9535
          Check your bulbs, fuse rating and perhaps try an original switch. I would go OEM for the brake light switch. I'm not sure about Autozone brake light switches. It could keep you from getting a ticket or worse getting rear ended. I have several OEM used brake switches if you're interested.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • blizake500
            • May 2014
            • 424
            Yea I am! Can you send pic of one?
            • UDMRacing
              • Oct 2013
              • 48
              A short? You sure? A short is a positive going to direct ground. Causing a fuse to blow if your lucky, otherwise it would continue until the wire or circuit failed.
              • blizake500
                • May 2014
                • 424
                ANybody had this problem????
                • cgk_iii
                  • Dec 2012
                  • 616
                  Check if you have the correct fuse and correct bulbs. And like reelizmpro said get an oem switch instead of "import direct" or whatever switch auto zone sells.
                  Fuse number 6 and 10 should have a 7.5A fuse
                  • efficient
                    • Feb 2012
                    • 3312
                    Im having a problem with my brake light switch aswell and its a fae brake switch I bought from bma. My problem is that my lights dont work in the night or mornings when its cold, they work fine during the day. I adjusted the switch and its barely holding on so it comes on real fast when they work. I cleaned the contact points on the rear lights and put new bulbs and nothing.l also replaced the little box on driver side trunk with a late model one from the junkyard and nothing. Only thing I can think of is replacing the switch with a oem one. Any suggestions?
