Idle Control Valve ???
  • grlaneriejr
    • 321
    Does anybody know if you can clean the ICV on an M10 engine, or does it have to be replaced when it's bad.
    My car will rev up and down between 800 rpm and 1500 rpm, but only some of the time. Other times, it's fine.
    Any ideas?
  • LikeCDoos
    • Jan 2004
    • 2522
    Is the a step by step walk through on how to do this? i'd like to clean it out because i have a rough idle when cold sometimes.
    • Simon325isport
      • 142
      I clean mine out on a regular basis (every 6 months) with carb cleaner. Keeps it working!
      • aaron_silva
        • 1785
        I believe you have a m42...I think. Just undo the nuts holding it to the intake manifold and undo the top hose and the bottom hose and the electrical conector. Remove the unit and clean it out (carb cleaner). Install is reverse of removal. The bottom hose was a pain to get back on (for me at least).
        Aaron
        • eliasmavs99
          • 58
          On my m10, the car does the same thing. I've cleaned throttle body and ICV, adjusted valves, new injectors, new spark plug and wires, new o2 sensor, new cap and rotor and still there is fluctuations in the idling revs from 700-1500
          • grlaneriejr
            • 321
            Does anybody know where it is on the M10 engine? Is it under the manifold or on top of it?
            • Bill 84 318i
              • 1600
              I had a wierd idle for awhile too. Not like your guys, but different. Two ICV's and three ICU's later, I finally got it to resemble a normal idle.
              On an M10, you can't miss the ICV. It's right on top...the black thing (I now have an aluminum one - there were two versions with the aluminum being the later one) to the right of the yellow transmission dipstick in the picture.
              • grlaneriejr
                • 321
                Thanks for the pic, Bill.
                How do you clean it, just take it off and spray carb cleaner into it?
                • Werksmini
                  • 1658
                  Thats what I did the other day, spray the stuff through it untill the stuff coming out isnt black. I have an m20 ICV that goes straight through so it may be a little different.
                  I bombed Korea every night.
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    My M10 idles at about 850 and fluxuates +/- 50 rpms. That's normal, correct?
                    Originally posted by Gruelius
                    • Jand3rson
                      • 37587
                      Is that your engine, Bill? It's fucking clean!
                      • LikeCDoos
                        • Jan 2004
                        • 2522
                        Aaron
                        I've got a M20, i'm guessing it's somewhat the same...
                        • Bill 84 318i
                          • 1600
                          Yeah...about two years ago. I haven't touched it since (aesthetically, anyway).
                          Yeah Ken, that sounds like what my engine does. I guess it's normal.
                          • LennysEleven
                            • Mar 2004
                            • 163
                            Could someone post a pic of the ICV on an M20?
                            thanks
                            Nick
                            • James Crivellone
                              Head Janitor
                              • 6302
                              thanks
                              Nick
                              silver cylinder
