OEM fitment Parallel flow...Here is the info. Get to making icecubes.
  • mpowerful
    • Jul 2013
    • 1273
    Just wanted to let yall know that an OEM fit parallel flow condensor exists for the e30. I have seen several threads here and at the other forums trying to fit a parallel flow from something else but that isnt really needed. I broke my tube/fin condensor taking it out for my 24v swap so I got on worldpac and ordered up this one. I got it at cost (90 bucks) but the list on worldpac is 400+. In other words I suggest trying to shop it around unless you have a worldpac account. If you have carquest nearby then you can order through them since they own/use worldpac. Anyway I used this condensor (bolts right up) with custom lines (e30 lines with e36 m52 compressor fittings), the m52 oem compressor, oem evap, and recently changed drier. I didnt change the expansion valve. Put in 900 grams of 134a. Here are the pics. Puts down serious icecubes. The pic of the pyrometer is at idle after idleing the car for about 45 mins so underhood temps were scorching. Fan speed 2. The ambient was probably around 80f.
    Oh and I just found it on rockauto for 75 bucks. https://www.rockauto.com/dbphp/x,cat...-PRO_6590.html
  • nrubenstein
    • 3148
    I've received a serpentine under that exact part number in the past. FWIW.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • mpowerful
      • Jul 2013
      • 1273
      Order it using the vista pro number. On worldpac it will say under details that it is parallel flow.
      • nrubenstein
        • 3148
        I was referring to the Vista-Pro part number.
        • jeffnhiscars
          • Jun 2011
          • 6011
          I got my bolt in PF from Amazon for about $80. The pic is of a serpentine but its a PF.
          Alice the Time Capsule
