all gauges except speedo dont work
  • nickmpower
    • 82
    doesnt this ussually mean a blown fuse? i looked at them and they apeared all not be blown and some werent there (accesories?) so i took one out and put it in the empty slots and still nothing. What else could be wrong? i am going to have another gauge cluster soon
  • BavarianBimmer
    • 951
    no no don't buy anything untill you've checked your speedsensor unit and connector onto your gearbox, a bad connection is a common problem for E30's
    1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
    1997 E36 328iT
    1990 E30 325iT 24v SOLD
    1989 E30 325i 2.7i M-Technic II SOLD
    • nickmpower
      • 82
      all the gauges except the speedo DONT work and the gauge cluster is free :D
      • nickmpower
        • 82
        still doesnt work with the new cluster, anyone know which fuse it is?
        • nickmpower
          • 82
          come on guys, i really need this fixed today
          • Bryson
            • 1490
            i think it's the same fuse as the reverse lights, if anyone knows off hand which that one is
            edit: that's probably where your short is.. the reverse light switch cable, it passes through the shift tunnel
            • nickmpower
              • 82
              yes the reverse lights dont work! sorry i dont exactly know what u mean by shuft tunnel...can i get at it through the interior by lifting the shift boot? probably not, i guess im gunna put it up on some ramps
              • Kavkazia
                • 394
                Speedometer plug is located on your diff. make sure the plug isn't rusted out, and it's in good shape. Usually, water gets stuck on plug because it has rubber boot around it, and after while it starts to eat the metal, and usually thats what causes the speedometer plug not to work.
                95' M3.
                90' 325i Turboed.
                87' 325eS Fixed.
                • 318driver
                  • 1714
                  This happened to me the other day, it turned out to be fuse 10 7.5amp. Hope this helps.
                  90 325is
                  IE stage 3s and refeshed m20....
                  • Bryson
                    • 1490
                    you can see it by pulling off the shift boot. pull it off and there should be a wire running through the rubber thing around your shifter, give that wire a good tug enough to move it about 1/2". replace the fuse and test to see if there's still a short, you can either run around with it like that or buy a new cable if that was the problem. hth
                    -bryson
                      • 34847
                      have you checked the sensor in the diff? that's usually the cause of a broken speedometer.
                      • Fuggly Stick
                        • 79
                        Sometimes the wire gets frayed by the sensor in the diff. Thats what happened to me.
                        • boom-monkey
                          • 1104
                          It's definately fuse #10. I couldn't find any 7.5's though so I just put a 10 in and it has had no ill effects. Good luck with any future electric gremlins :twisted:
                          • Super Eta
                            • 1884
                            dont you guys have BMW Owners Manual becuase i sure do and i always use it when fuses go out.
                            Very handy so grab 5 bucks and order one off ebay, yep 5 bucks and real handy.
                            Just a tip
                            Back to the topic.
                            Like the guy above said its probably fuse #10 but i am totally sure myself.
                            Anyway goodluck
                            • franz
                              • 631
                              Uh, he said his speedometer works, in so many words. :roll:
