Tranny Question
  • Red325es
    • 140
    Tranny Question
    Does anyone know if an e28 528e getrag 265 tranny will work corectly with my eta? :?:
  • Jordan
    • 12907
    different output flange.
    You want a Getrag 260 out of a 325e/i
    Josh on this board is selling a 260 from a 325iS.
    https://mtechniqueabs.com/
    • Red325es
      • 140
      The i tranny's will not work, as the i tranny's do not have the crank reference sensor holes. only 87' e and pre 87' 260's will work. I was just not sure if the 265 would bolt up?
      Output flanges are also interchangeable with the correct 30mm thin-walled socket. thanks for the info about the tranny FS though.
      • Jordan
        • 12907
        The marking for the sensors are there.... you just need to drill them. The bellhousing is soft aluminum, it isnt hard to drill.
        • Red325es
          • 140
          Oops............I should have kept a good used tranny then, and had a machine shop drill it out. Oh well. time to find a new tranny. Has anyone ever delt with the euro depot?
          • Jordan
            • 12907
            Euro Depot is owned by Joel, used to be friends with him back when I lived in NH.
            Joel is good people, won't do you wrong.
            • Red325es
              • 140
              awesome thanks for all the help! :D
              • EVOIIIM3
                • 315
                265 are for the US M3's to. They have a removable bell housing. So if you could attach the proper housing then yes it would fit.
                however you are better off just getting a G260 a bolting it up.
