Stupid question: what is this connection for
  • bowtie2bimmer
    • 830
    As you can see, the female end fell apart. But I have no idea what it does. I thought coolant temp sensor but my gauge still works. A/c fans still work too. Can anyone help me out?
    Also recommendation on how to fix? Each wire is color coded but I don't know which prong to attach it too
    Sent from my SCH-I545 using Tapatalk
    1987 BMW 325ic - Emma
  • rzerob
    • Jun 2013
    • 2315
    Looks like radiator temp sensor. That controls your high and low speed accessory fan on an early model.
    read this.
    • Sea Aych
      • Apr 2013
      • 765
      I think that's the temp switch for the aux fan
      Mine's on the other side of the rad though, so i'm not sure.
      edit: rzerob beat me to it, looks like that's what it is
      1988 Atlantisblau Euro/Japanese 325i Cabriolet
      1989 Schwartz 325i - now M50 powered! - now very dead
      1998 Toyota 4Runner Limited
      My 17,000km Big NA National Parks trip!
      • bowtie2bimmer
        • 830
        Ok so those small electic fans in front of the rad will kick on once it hits a certain temp? I knew they would kick ok when the a/c button was activated, didn't realize they operated on temp as well.
        • 101
          • Jul 2011
          • 764
          yep - its a temperature switch for the aux fan. Same thing happened to my eta ... I was able to purchase a plastic plug from BMW and slide those wires into it. Good as new.
          Two things will turn that aux fan on:
          1) Air conditioner operating (blue snowflake lit on the HVAC panel).
          2) Temperature of the coolant in the radiator.
          It's a two speed fan - so there are three wires - low speed, high speed and ground.
          If your aux fan is coming on regularly without the air conditioner being on, its time to check your mechanical fan clutch on the engine driven fan for proper operation.
          101
          The E30 collection:
          1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
          1987 325is - Delphin / Black Sport (son #3's)
          1987 325i Convertible - Triple Black
          1989 325iX Coupe - Diamondschwarz / Black Comfort
          1990 325iX Coupe - Sterling Silver / Grey Sport
          1981 Fiat 124 Spider 2000 - Green / Tan
          1998 Volvo V70 GLT - White / Tan
          1998 Volvo S70 T5 manual - White / Taupe
          2001 Ford Windstar - Silver / Grey (parts hauler)
          2006 Lexus GX470 - White / Tan (tow rig)
          • bowtie2bimmer
            • 830
            Great. I didn't realize bmw could get me that plug. Do you have a part # by chance?
            From real oem I think its 61131378410
            • Sea Aych
              • Apr 2013
              • 765
              yup, that's right
              • Stanley Rockafella
                • Aug 2011
                • 4060
                that plug is just for the housing and not the wires that feed into it.
                There's another part number for the correct wires (if you wanna do it the right way) to splice the wiring into the housing
                61-13-0-007-441 *3
                • bowtie2bimmer
                  • 830
                  Oh... so really I just need 3 of those female leads. The other part just makes it look pretty
                  • 101
                    • Jul 2011
                    • 764
                    Pretty, yes, but the plastic housing will keep those "females" in place, keep the dirt out of them and prevent them from touching each other and sparks flying.
                    Wait - we're talking about a connector housing here, right?
                    That housing was about $2 rougly 2 years ago. Go for it!
                    101
                    The E30 collection:
                    • rzerob
                      • Jun 2013
                      • 2315
                      The plastic housing is a cheap part but it serves no real function other that keeping the females leads together. You don't really even need the BMW OEM female leads either. Take a but crimp connector and put it over top of the prongs in the sensor it should fit good. That can hold you over until you get the OEM parts. Dirt is not going to get inside your connection and you have no worries of sparks flying with out the plastic housing. Female leads are insulated so are but crimp connectors. If you have any questions ask.
