M42 Upper Manifold Removal
  • Eurospec
    • 2612
    I will be having to remove the intake manifold on my M42 to access a water line that needs to be replaced. Aside from replacing all pertaining gakets, what do I need to be aware of as this will be the first time I will be removing it. Any pointers? TIA.
  • 2002maniac
    • 4260
    unless you have little girl hands it is quite impossible to reach the hose's under the manifold. If I ever need to remove my manifold again I'm going to plug them.
    • hamann318is
      • 3382
      The TB is something magical to get off. You're going to have fun with that.
      The BMW 318 is back. With a vengeance.
      • AdamF 88iS
        • 2051
        It's not that hard. You just have to angle it just right to get it around the hose fittings out of that heater plate.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • Eurospec
          • 2612
          Successfully removed the TB and manifold and now have a couple questions before I proceed.
          -One of the stud bolts that holds the Manifold in place came undone. Should I take any extra precautions? As for tightening all the nuts, do they need to be torqued to a certain spec?
          -Would you guys recommend I clean the manifold and throttle body? If so, what should I use?
          • Rob
            • 8166
            carb cleaner works well.
            I didnt really have any problem pulling any of that shit off last time I did it fwiw
            BEERTECH
            • Mike 91 318ic
              • Jun 2004
              • 429
              remove the 2 TB heater elements and hoses as they rob power and the hoses are a pita to replace. Unless you live in an area that gets to -20
              • hamann318is
                • 3382
                Yeah, I know what you mean. It's just weird to find that angel the first time. I spent about 20 minutes just playing around with it. I'd get it to a point where I'd think it'd pull off, but then it'd fall back. It's not hard, but trickier than I thought.
